Applied first coat of spar varnish over top of cured epoxy! It has been 7 days today in 72 deg. shop since coat...and it is still sticky!
NOTE: neither appears to be bad products.
Just don't use together!
West System epoxy says Z-spar is their best choice, or System 3 (which make both epoxy and spar varnish) I have used MAS-90 epoxies before, with Man-O-War varnish, with no problems.
So, guess what I started doing today?? Wiping down the entire exterior with mineral spirits to remove uncured varnish. With a lot of effort, it is coming off, back down to sanded epoxy.
If you are going to varnish over epoxy - do not use these two products together!
