doug hodder wrote:I like it...it's an innovative design, whatever you conceive, you can achieve...thinking about hard or soft side on the raised portion? Doug
Ron Dickey wrote:welcome aboard....![]()
Don't know how long you have been watching this forum there are several who have done the lifting roof thing.
Andrew offers a couple on his site.
http://www.angib.pwp.blueyonder.co.uk/t ... tear48.htm
also check in the Hall of Fame upper left of this forum.
http://home.earthlink.net/~g.teague/
George offers several interesting ideas.
we would love to see any new ways that pop ups can be designed.
Ron D.
Miriam C. wrote:I don't do water dynamics but I doubt if you need a real high lip to keep water out under normal conditions. I think the wider the cap edge is the smoother it will look.
Tambour is a flexible material and can be applied to concave or convex surfaces as well as flat walls and ceilings, round or square columns. It installs easily and lends an exciting look to living rooms, bathrooms, kitchens or commercial environments.
Not appropriate for dry climates or environments that are not able to maintain year round relative
humidity (RH) of 40 to 60%
wlivesey wrote:I've added the overhang to the popup. I think it looks pretty good. Here are a couple of samples with it in the up and down positions.
