Thoughts on my design
Postby Miriam C. » Sun Jan 06, 2008 10:41 am
8) Well since Len LaDonna has an electric lift on his hatch I think something is workable. Just need some Jimmy riggin and cables that come down with the last sides is what comes to mind. I however am neither mechanic nor engineer.
It seems if the cables pull the top down with the sides, when the sides are secure so also will be the top. I don't think that will handle the wind issues though. :?
Postby angib » Sun Jan 06, 2008 7:57 pm
The one other way you can arrange the 'wall' panels is to fold them both the same way, so that the pop-up becomes quite offset either forwards or backwards. Here is an animation and section drawing:
As you can see, it's not too hard to build in a gas strut to open the roof. This design was used for a decade or more by a British motorhome company.
The downside is that the parallel folding means that all the parts have to be exactly the right size or it won't fold exactly parallel.
Andrew
angib
5000 Club
5000 Club
Images: 231
Return to Member Designs
