Wos wrote:Batteries are not created equal. The output voltage of one, if slightly higher, will discharge into the other. The weaker one will accept the extra charge but will not be able to maintain the higher voltage. The batteries will eventually discharge back and forth and they will die.
Steve F wrote:Thanks guys, they are going to be exactly the same, same purchase date etc as the second battery in the Jeep needs replacing. I'll see what the manufacturer recommends and take it from there but it sounds like leaving them isolated when not charging is the safe way to do it.
Cheers
I agree with that - Optimas are special batteries (I have 4 in different vehicles, including one in my tear) and paralleling them won't 'cost' you nearly as much as with cheaper lead acid batteriesjeep_bluetj wrote:I just tie mine together. 2 optimas sitting in the TJ in parallel. 3 years going strong. Only time I'd ever pull them apart is to use em to weld with. Never needed that yet, so they've been hooked in parallel since I installed em. (And I bet my welding rods are soaked... should get new ones....)
It's VERY common in ambulances, fire trucks, motorhomes, etc to have parallell connected batteries for more capacity. (Also pretty common for serial connected, but that's better covered in the links that Dale posted.)
alanm wrote:...you have the choice of lead acid, gel or AGM battery construction.
kartvines wrote:I understand that overall most of you think the Optima is a good battery for the price, I thought would use the blue top, after review many post it seems as if most of you have gone with the yellow top is that correct?
