Here is a picture of a 4" riser
George
madjack wrote:Alphacarina wrote:The Flexirides have an adjustable arm angle - You can play with it all you want to adjust the ride height so as to match the coupler to your tow vehicle . . . . . .
Don
...and cost about 100 bucks more, once you gettem to your doorstep!!!!!!!!!! I really prefer the FlexiRides...just not 100 bucks more...
Alphacarina wrote:Order then direct from Flexiride - You'll save about 25% off SWW's prices, plus you'll get the genuine Flexiride hubs, which SWW substitutes for cheaper, generic hubs
Don
madjack wrote:WE go with a 0* start angle and use 205-70-15 tires...
asianflava wrote:...#9 have 5-bolt hubs...
brian_bp wrote:madjack wrote:WE go with a 0* start angle and use 205-70-15 tires...
Sorry for the sidetrack, but...
205/70-15? Can I assume that these are not Special Trailer (ST) tires, which are generally available only in 75, 80, and 85 series? (and even then, only one aspect ratio for any particular width and wheel diameter) I notice that Carlisle has a low profile ST line, but they're 60 series.
madjack wrote:brian_bp wrote:madjack wrote:WE go with a 0* start angle and use 205-70-15 tires...
...you are correct...they are standard pasenger car tires...I have never used the "ST" tires as replacements on utility trailers and have never seen any problem using them...since dry rot sets in after 3-5 years anyway, wear problems are a moot point........
