I recently had the trailer weighed, partialy loaded, and it came out at 1060 lbs with a toungue weight of 160 lbs. I decided to replace the complete axle on the trailer because the existing one is only rated for 1000 lbs and I don't want to risk another cross country trip. So the new trailer axle/spring kit arrived this week fron Northern. I purchased the 2000 lb axle kit with springs and hanger hardware. I will have to alter the spring pads to batter match the trailer width of 55 inches outside to outside.
Determining the axle placement is easily done as well, but I don't know how to determine the rear spring shackle placement with respect to the angle that is best used. I know that I don't want the sackle to end up at an angle close to being parallel with the frame in its loaded state. Can anyone give me some help with this?
