Nope - Not even CLOSE!Larwyn wrote:The 240 volt single phase winding is one winding. It is center taped by the neutral, one leg is 120 volts more negative than the center tap, the other leg is 120 volts more positive than the neutral, netting a difference in potential of 240 volts. They have no choice but to be 180 degrees out of phase by virtue of the center tap. No special tricks or transformer voodoo required.
eamarquardt wrote:You now seem to accept that the two drops are 180 degress out of phase.
I have never tried it, but I think you can get dc through a trasformer if you switch it on and off fast enough. If it works, it will be some form of ac on the secondary though.
Yes, they both swing positive and negative and by the same amount - Both sides are identical other than being 180 out of phase, so neither swings more or less positive or negative than the otherLarwyn wrote:The alternating current sine wave is by definition swinging positive to negative several times a second (60 in th US). At any given instant in time the two are still 180 degrees apart therefore one is always more negative or positive than the other. Otherwise there would be no difference in potential, no electromotive force, no voltage at that instant
