Mounting floor to trailer.....
Postby The R/C Man » Tue Apr 19, 2005 9:57 am
Hey everyone!
Here is an idea that I would like to run by you. The pic shows a side view of how I would like to mount the floor to the frame. The floor will be constructed using Gorilla glue and the walls will be screwed to the sides of the floor as well as through the frame of the walls into the floors 2x4's. This should keep the top sheet of plywood from going anywhere. The bolts will go in from the bottom and stay in place using lock washers and some lock tite compound. I would like the camper to be removable from the trailer just in case.. I hope I explained that ok. Let me know what you think.
Greg
Over time science has shown that the simplest answers are usually the correct ones.......
The R/C Man
Images: 36
Postby IraRat » Tue Apr 19, 2005 10:12 am
Hey, RC. Are you referencing any TD plans yet? You sure seem to know what you're doing, but I just wanted to point out that a lot of TD plans don't use a bottom sheet for the floor. Just insulation coated with asphalt fiber "stuff."
If that second sheet is PERMANENTLY installed to your trailer, that's a different story.
--Ira
IraRat
Forum Storyteller
Postby mikeschn » Tue Apr 19, 2005 10:51 am
Hey Greg,
The concept looks fine. Just drill all your pilot holes in the frame first, and in the wood second, before drilling your counterbore for the t-nut.
And I ditto what Rat said about the bottom plywood! It's not necessary.
Postby IraRat » Tue Apr 19, 2005 1:29 pm
One more thing:
The Cubby only requires 2 by 2 framing, not 2 by 4--so if you're doing a 4 X 8 TD, that's something to consider for your removeable, because of the lighter weight with 2 by 2s.
--Ira
IraRat
Forum Storyteller
Postby TomS » Tue Apr 19, 2005 2:01 pm
I agree with Ira. 2x4 framing for the floor is probably overkill.
I did something simlar with my floor. I counterbored each bolt mounting hole with a Forstner bit. After the floor was bolted down to the trailer frame, I filled each hole with wood filler.
If you go here
http://www.tomswenson.com/teardrop/floor/index.shtml and click through to slides 5 and 6, you'll see what I 'm talking about.
My purpose here was to keep the bolt heads from protruding above the floor. I don't know if the wood filler would hold the bolt heads still while I backed off the nylox nuts. But, I'm sure epoxy mixed with some kind of filler material would hold those bolt heads good and still.
Tom Swenson
[email protected]
TomS
Postby samstoybox » Tue Apr 19, 2005 6:57 pm
One more thing I always do with T-nuts is to make sure I can't accidentally push them out with the bolt I'm trying to thread into them. This is especially important if they will be hard to reach like the ones you've planned. I generally use two or three panhead screws:
Sam Cancilla
http://www.samstoybox.com/teardrop/ - My teardrop (re)build site
samstoybox
Postby WoodSmith » Tue Apr 19, 2005 7:34 pm
It may be overkill on a permanently mounted TD but I think that it might be a good idea on one that may be removed. I think that the added strength would be a good thing when you are rolling / sliding / lifting the TD off of the trailer, as well as when it is in storeage.
Glen Smith
Build Journal
WoodSmith
Images: 40
Postby mikeschn » Tue Apr 19, 2005 7:37 pm
samstoybox wrote:One more thing I always do with T-nuts is to make sure I can't accidentally push them out with the bolt I'm trying to thread into them. This is especially important if they will be hard to reach like the ones you've planned. I generally use two or three panhead screws:
I never gave that a thought before, and then one of my t-nuts on a high flying rocket broke loose at a critical time... so , yea... that's a good idea!
Postby The R/C Man » Tue Apr 19, 2005 8:36 pm
IraRat,
No I haven't refered to any plans. All the pictures on this site as well as the help from you guys on this board is more than enough to build it.. :D
I figure the botom sheet would protect the foam from rocks add a bit more to the R value and give a little extra strength to the floor, not that it will need it. Anyway the 1/4" sheet is only $10 how much does the asphalt stuff cost? Oh, the 2x4's are only going to be full size for the edges. I plan to rip them down the middle for the center supports....
mikeschn,
Yap got the pilot hole thing.. :D You mentioned High power Rockets. I am building a 6" diameter by 8' tall level 3 project. It will have a central 54mm and three 38mm out boards.... I am hoping for 17,000ft :o
TomS,
I think I looked at your site before. I rember the cat.... I got some good ideas from there. Thanks!
samstoybox,
Awesome idea for holding the T-nuts in place! I would have used epoxy, your way is better.... :applause:
Greg
The R/C Man
Images: 36
Postby mikeschn » Tue Apr 19, 2005 8:54 pm
The R/C Man wrote:IraRat,
mikeschn,
Level 3 eh... I've been procrastinating on my level 2. I passed the written exam last fall, but the delay on the rocket was too short... (I was at the mercy of the lauch vendors) I plan on launching my level 2 again this summer, and then, maybe I'll have to pick your brains for my level 3.
Postby asianflava » Tue Apr 19, 2005 9:13 pm
Aww Man, I thought you got your Level 2 last year, I'm just level 0. At work, we are starting our rocket building program with the local elementary again. It's lots of fun, also gives us an excuse to play with rockets and get paid for it.
asianflava
Postby The R/C Man » Tue Apr 19, 2005 9:18 pm
The funny thing is I don't have my level 2 yet either. I have the rocket in the garage for it though. I should launch it within the next couple months or so. The cool thing is that I am a dealer so parts are readily available... :D
Greg
The R/C Man
Images: 36
Postby IraRat » Tue Apr 19, 2005 9:35 pm
That underside floor just isn't necessary for rock damage, because the way you're going to finish it, it will be fine.
Also, again, you probably and simply don't need to go 2 by 4 anywhere on that frame--and since you're doing a removable, this would make a big difference in the weight.
--Ira
IraRat
Forum Storyteller
Postby The R/C Man » Tue Apr 19, 2005 9:47 pm
Thanks!
I will just rip them down then...... and save a couple bucks in the process....
Greg
The R/C Man
Images: 36
Postby ALAN GEDDES » Tue Apr 19, 2005 10:17 pm
I' ve done both methods of construction and really think the 2x4 is overkill. The closed bottom with insulation is the better construct in my opinion. We tend to get carried away sometimes and over engineer these things. When completed that curved plywood box is super solid.
Alan
ALAN GEDDES
Images: 34
