WebFoot wrote:I think some ford small pattern 5 lugs are also 5 on 4.5"
brian_bp wrote:WebFoot wrote:I think some ford small pattern 5 lugs are also 5 on 4.5"
I understand from various reports that that's the Ranger (and maybe a Mustang or something). Trailer hubs tend to need a big centre hole, and the hub need to clear the wheel at that hole (not fit snugly), so the Ranger wheels with big holes for 4x4 front hubs seem like the most likely fit to me.
WebFoot wrote:...time to look at imports Im guess'n.
WebFoot wrote:Dale,
I did get the HD trailer with the 5 lug hubs, just so that I had a better possible selection of aftermarket wheels.
Aaron, thanks for the tip, I just have a bunch of moapr rallys and pondering thier use on my build was too easy..
Angib, great point, I had forgotten about higher wheel bearing loads with an offset wheel, which might be pushing it with something like a 14x6 which is stock mopar rally size in the 14" version.
What I need/want is a sporty aluminum 13x5" or 4.5 in this pattern, trying to get away from the always obvious white 'trailer wheel" look...time to look at imports Im guess'n.
Thanks guys.
Webfoot
GregB wrote:
I'm using these 15" with a HF frame but then I realized that with 0 offset, they would rub against the frame. I replaced the axle and added a couple inches for looks and so I can have easily replaceable bearings. The axle was only about $110 locally. I ordered the tires and wheels at a Les Schwab and they did the powdercoating for me as well.
GB
