RichAFix wrote:... I am leaning more towards 1"x2"x.188" C-channel for the frame.
... but is 1" going to give me enough beef on the frame to weld/bolt the axle to the frame? I plan on using a torsion axle...
Dexter wrote:The preferred arrangement should place the longest vertical section of the axle bracket directly under the most rigid section of the frame member.
RichAFix wrote:... I had my mind made up I was going to use 2"x2"x.125" square tube for the frame, but after seeing everyone talk about how overbuilt most of these end up I am leaning more towards 1"x2"x.188" C-channel for the frame.
...By going with the c channel rather than the square tube I save about 30 pounds ...
The originally proposed 2"x2"x0.125" box-section would weigh about 3 lb per foot, and so the 1"x2"x0.188" channel will save 3/4 of a pound per foot... maybe 12 pounds for both main rails of a trailer with an 8-foot body (36 lb total instead of 48 lb). Is that a problem?
- A 1" flange is very narrow to bolt an axle bracket to, whether it's torsion or leaf-sprung. For example, the Dexter #9 bracket is 2" wide and assumes the use of a 1/2" bolt, as shown below - now cutting a 1/2" hole through a 1" flange is taking away quite a lot of its strength, not to mention trying to squeeze a 3/4" AF nut onto a 13/16" wide flange
RichAFix wrote:Of course that makes bolting the axle on impossible as the frame would be enclosed and I wouldn't be able to get to the inside of it.
RichAFix wrote:...I think I will just go back to "plan A" and use the 2"x2"x.125", at least for the frame sides. Of course that makes bolting the axle on impossible as the frame would be enclosed and I wouldn't be able to get to the inside of it.
RichAFix wrote:... My 30# savings is based on side rails, front/back/one cross rail and the a frame part of the tongue. I still have a 2"x3"x.125" tongue, which may be overkill, but I have had a trailer that failed at the tongue so I prefer that a bit stronger for my own peace of mind...
RichAFix wrote:- A 1" flange is very narrow to bolt an axle bracket to, whether it's torsion or leaf-sprung. For example, the Dexter #9 bracket is 2" wide and assumes the use of a 1/2" bolt, as shown below - now cutting a 1/2" hole through a 1" flange is taking away quite a lot of its strength, not to mention trying to squeeze a 3/4" AF nut onto a 13/16" wide flange
Thank you, that is exactly what I was worried about, your explanation makes sense to me. I think I will just go back to "plan A" and use the 2"x2"x.125", at least for the frame sides. Of course that makes bolting the axle on impossible as the frame would be enclosed and I wouldn't be able to get to the inside of it.
