Can I just mount the 12v fuse panel and ground block onto a piece of plywood? Or would it be better to find some sort of panel box?
Thanks,
Reddirt
Reddirt wrote:Steve,
Who makes your panel? I wonder if they sell in the US?
Was it designed for boats?
Thanks,
Reddirt
madjack wrote:RD, the fuses are blade type and the two "buttons" are push button circuit breakers for my 120vac...the fuse/ground block(around 10 bucks) and the circuit breakers(under $3.00 apiece) came from www.waytekwire.com ...oh yeah, the battery is fused as well and sits in the box under the panel........................
p.s. the black panel is made from painted formica and there is a DPDT switch between the MasterSwitch and the circuit breakers, for controlling power to and from the battery charger and no, I probably wouldn't use the cheapy charger from WallyWorld(20 bucks) again.........MJ
