I want to be sure I've got all the old GP grease out before I re-pack them with synthetic.
Thanks,
Joseph
Joseph wrote:Has anyone ever successfully removed the inside bearings from a set of HF hubs? I think they should just tap out but they appear to be glued in.![]()
Thanks,
Joseph
Geron wrote:You're probably trying to get the grease seal out. The bearing should just fall out once the seal is removed.
steve wolverton wrote:I find that a slide hammer works great for this stuff. If you don't have one, you might should consider it. I have a cheap version (The Silver Slapper) and it has attachments for different jobs. You can do body work with them (pulling dents), remove bearings, impress the ladies, etc.
Joseph wrote:Geron wrote:You're probably trying to get the grease seal out. The bearing should just fall out once the seal is removed.
Well, if removing the grease seal allows the bearing to fall out, it sounds like that's what I need to do. So I guess my next question is, since pulling the grease seal tends to trash it, where do I get a replacement?
Thanks,
Joseph
arnereil wrote:I still carry a set of bearings and seals with me... they cost about $30.00, and fit into a small box.....
If I ever have need of them, they will be one of the best investments I have ever made........
JunkMan wrote:arnereil wrote:I still carry a set of bearings and seals with me... they cost about $30.00, and fit into a small box.....
I alos went out and bought a spare set of bearings and a seal to carry with me. A couple of years later, I was cleaning out the boat, and tucked into a corner of a cubby hole that I never used was a set of bearings in a plastic bag!The original owner must have also believed in carring a spare. So now I also have 2 sets!
bdosborn wrote:"The timkem bearing number is 30205 M 90K M1 (the 30205 is the important part).
and the seal is (milimeter measurment) 30x52x7... the 7 is the seal width. You need to know the '7' part.
Geron wrote:Any auto parts store. Just take what's left of the old one in for a match.
