water tank support?
water tank support?
Postby nikwax » Thu Feb 14, 2008 10:42 pm
I've just taken delivery of a 15 gallon ABS water tank, which I intend to mount beneath the front of my trailer. I reckon some sort of metal straping would work. At the hardware store today, the best I could find is 22 gauge pipe hanging strap. I'm concerned that this wouldn't have the strength to hold 120 lbs of water securely, however, so I'm looking for other ideas.
Any thoughts or experiences?
nikwax
Images: 30
Postby Steve_Cox » Thu Feb 14, 2008 11:08 pm
4 each 5/16ths threaded rods through the floor with 2 pieces of 1" angle iron under a support piece of exterior plywood under the bottom of the tank.
Steve_Cox
Images: 196
Postby madjack » Thu Feb 14, 2008 11:56 pm
...or a piece of 1.25" galvinized strap used to mount garage doors...my local ACE has a ton of it, in barrels, back by the aluminum angle/channel/ect..........
madjack 8)
Postby Steve Frederick » Fri Feb 15, 2008 7:28 am
I used a salvaged bed frame for iron, welded, you could bolt it also, together.
Bolted it to the frame..
Hardware is stainless.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby nikwax » Fri Feb 15, 2008 10:26 am
you guys rock :thumbsup:
nikwax
Images: 30
Postby len19070 » Fri Feb 15, 2008 10:48 am
Steve Frederick wrote:I used a salvaged bed frame for iron,
Salvaged Bed Frame is to Teardrop builders what Duct Tape is to Red Green.
Happy Trails
Len
len19070
Images: 24
