G-force wrote:Andrew: Your right, I want it like your top drawing, and not have the a frame underslung on the main frame. Partly for looks, partly because it already takes a 6" drop ball mount in my truck for my utility trailer which has a 16" deck height, my tear is going be be lower and I am really trying to keep the coupler up as high as I can without goose necking it.
Trackstriper wrote:The fourth side of the tongue to side rail weld would be sketchy, hard to access, but is it necessary?
Trackstriper wrote:For my build I'm planning to use an "A" frame tongue in the same plane as the main side rails, but with the front cross-member above the tongue and side rails. Does anyone see a problem with this that I'm maybe blind to?
