Jst83 wrote:Welcome Steve,
You've bought the trailer, yep your hooked there's no turning back now.![]()
As Doug said you'll get a lot of ideas on here but the bottom line is it's yours build it like you want and have fun.
We've got a big gathering forming in Brown County, IN in May
I did a search it's just a little over 3 hours from you, it would be a good chance to see a lot of different styles and meet a lot of people first hand. Check it out the Midwest section
Again welcome to the Fun and look forward to meeting you at a future gathering.
Scott
Roly Nelson wrote:Welcome Steve, that sure looks like a long trailer you've got there. Just looking at the pics, and I can't say for sure, but the axle may be a bit too far back which might create a fairly heavy tongue weight. Also, is that short tongue standard for that trailer? My concern is the flex created with such a short purchace back to that first cross member. How about it, fellow builders, does it look right to you, or am I out in left field with my comments? Just trying to be helpful, I ain't no expert.
Good luck on your build. I suppose if you are going to load it up with bikes, that means the galley will require some changes to allow access for them. Can you provide some sketches so we can tell what inovative designs you are planning? You've got a good start on your pics, just keep 'em coming.
Roly
Miriam C. wrote:to the playground Steve.
Had a look in your album and the trailer mods sure look better than the normal TSC trailer.
Are you planing on carrying the bike inside or out? Be sure to leave room for yourself
