by grant whipp » Sun May 08, 2005 12:07 pm
Good morning, All!
Thought I'd start off easy this morning and get sort of caught up on the happenings over here. Nice project, Mike! Hope you don't mind if I make a few comments/suggestions (as a few of you know, I've got a little experience with this sort of thing ... ;-} ;-} ...!)
• The Benroy design is a good basis - it's good looking and makes the best use of available space.
• I'm personally not in favor of the "box-on-a-frame" approach to the design. It's a simple thing to either narrow the frame or widen the body a bit to allow the walls to extend past the floor to hide the frame rails and really give the unit that finished look. After all, one of your design parameters from the beginning was to have an attractive, well-finished trailer in the end, and historically (as I've said before) the best known and respected vintage mfgs. hid the frame rails with the walls, including Benroy. And, it is NOT difficult for the first-timer to pull off successfully!
• Door placement: All of my 8'L models & designs have the leading edge of the door 16" back from the front of the profile, and the door is either 30"W or 32"W (my personal Off-Road Benroy Project has a 32"W door) with a threshold height of about 2-1/2". I'm 6'4" and have been camping in my 8' designs for 20 years and have not experienced any problems or discomfort either in entering the trailer, or exiting it from the laying-down position. (Two things we need to keep in mind during the design phase of our teardrops is 1, that EVERYTHING in a teardrop is a compromise - sometimes we get lucky and end up with a bed that is more comfortable than the one in our homes, but believe me, the rest is all compromise! - and 2, that we are building a CAMPING vehicle here - allbeit a LUXURY camping vehicle - NOT an RV!)
• Axle placement and tongue-weight: I'd have to check, but I'm pretty sure that the axle on my O-R Benroy Project is about 33" from the rear of the profile. I'll have a front overhead cabinet, and I'm estimating a tongue-weight of not much more than 100#, if even that. I came up with a general rule-of-thumb many years ago that basically says the axle placement on a teardrop WITH ADAQUATE GALLEY CABINETRY should be ABOUT 1/3 it's bodylength from the rear of it's profile, and it's proven to be pretty darn reliable (of course, as in everything, there have been exceptions to that rule!). Some of you may also know/remember that I have serious issues with the "industry standard" and "expert recommended" 10-15% tongueweight "rule" - I WON'T go into that here, but suffice it to say that I don't agree, and I've got over 35 years of experience in building and pulling trailers to back me up.
• Wheel size: I use 14" as standard, sometimes 15". I KNOW the 12s & 13s work well enough, but with a trailer this size (5'W), I think going it a bit bigger to 14" would look a bit more proportional, not to mention a slight increase in the safety factoy (oopppssss, did I open another can of worms, there ... ;-} ;-} ...?).
• Window size: The bigger the better! For traditionalists, there's the 12"Hx18"W (which is pretty standard and readily available), but the 15"Hx18"W offers a bit more visibility and airflow without taking much away from the traditional look. I've put large radiused corner windows in traditional-styled doors with great results, and even managed to get a 28"Hx18"W in that looked superb. Think airflow, and light-and-view as it might apply to possible claustrophobia!
Well, I think I'll call it quits with that. Remember I'm not being critical, just offering a few things to consider based on experience. GOOD LUCK with this great project! And, Good Luck to all you builders and potential builders out there!
In the meantime ...
CHEERS!
Grant
Celebrating
Retirement after over
32 Years of Building, Promoting, Supporting, Supplying, Living the Lifestyle, and Loving
Teardrop Trailers!"Life Moves a Little Slower When You're On Teardrop Time"The nature of Life, itself, is change ...
"Those who matter, don't mind, and those who mind, don't matter."
