G-force wrote:You need to find out the rated towing capacity, and maximum weight on the ball...both should be in the owners manual (assuming the manufacturere intended it to be used to tow.) Maks sure your trailer falls within those limits. GVWR is the maximum your vehicle is designed to weight full of fuel, cargo, people, etc. For example if a vehicle weighs 4000 pounds and has a GVWR or 6600 pounds, tham means it is rated to carry 2600 pounds of cargo. Somewhere in your manual should also be a GCWR, Gross combined weight rating, that is the total weight of your vehicle and trailer should weight.
Mike
Nitroxjunkie71 wrote:...I never knew that a manual transmission made such a difference. After all;...
catrinka wrote:If you are looking for a light cargo trailer, you might see if you can find a fiberglass one. Mine, from Trailers Unlimited manufactured in Edmonton was 700 lbs empty. Now that I have it converted, it weighs in about 2000 lbs. fully loaded. I pull it with my Buick Rendezvous and hardly notice that I'm pulling it. My gas mileage does drop a bit, to about the same as my city mileage, but still not as bad as a bigger rv.
Lloyd Christmas wrote:...So if I have understood and calculated correctly, I can't exceed 7,000 pounds total weight with my vehicle including the vehicle and the weight the trailer puts on the vehicle (via the tongue). My GMC truck weighs about 4500 pounds so I would assume my Yukon would be in that neighborhood. That would leave me with a trailer that could weigh up to 7,800 if only 2,500 pounds was on the tongue....does that sound right?
Lloyd Christmas wrote:... I think the bottom line is that I could pull anything I would consider.
Lloyd Christmas wrote:I would probably add brakes to be on the safe side...
brian_bp wrote:catrinka wrote:If you are looking for a light cargo trailer, you might see if you can find a fiberglass one. Mine, from Trailers Unlimited manufactured in Edmonton was 700 lbs empty. Now that I have it converted, it weighs in about 2000 lbs. fully loaded. I pull it with my Buick Rendezvous and hardly notice that I'm pulling it. My gas mileage does drop a bit, to about the same as my city mileage, but still not as bad as a bigger rv.
To me, the Shuttle from Trailers Unlimited looks very suitable for this purpose. Due to the light load of an RV conversion, the single-axle versions (Shuttle models with "S", not "T" on the end) would be suitable. The Shuttle comes in 4-foot-wide (maybe a minimal teardrop style?), 5-foot-wide (like Cathy's), 6-foot-wide (small travel trailer for Lloyd?), and 8-foot wide (full-sized travel trailer?). If you want to sleep across the width, and 7 feet seems ideal, you're out of luck. Each width is also taller than the next narrower series.
My guess is that a 6x14 Shuttle single-axle would weigh around 1000 lb empty, probably roughly 2500 lb as a fully equipped travel trailer, and still be able to carry 1000 lb of stuff, while being an easy tow for either of Lloyd's tugs. A 5-foot-wide would not have standing headroom for many people, but would be a bit lighter and even easier to pull.
I like the idea of one-piece body construction. Well, Cathy's is two-piece, because it is unusually long (for the width).
When I have suggested this type of moulded fiberglass cargo trailer to others, the conclusion seems to be that they are rare... perhaps the Shuttle is unique. They are certainly popular here, in various cargo applications, including rentals (by Trailer Unlimited and other companies, such as Budget).
