Here is what I have designed as an electrical system for my TD
Comments welcome...
DEE
Woody wrote:Can you ground 120 vac and the 12vdc negative ground to the frame and share the "common ground" as it were without feeding back to either side? Can this be done? I thought they had to be isolated. Educate me
mexican tear wrote:I have the frame tied to the green wireof the 120VAC. The white wire (neutral) also goes to ground. I was getting shocked until I tied the earth wire (green) to the frame. kai
