Hammerite on wood
Hammerite on wood
Postby tbeau » Tue Mar 11, 2008 5:08 pm
Has anyone put Hammerite over wood? And if so, how did it turn out? I think the hammered finish would look good on the outside of my camper "The Spartan". They have a deep red color that I think would look good on the walls. Black for the roof and maybe paint the frame in gold. What do you think? If not any other ideas for a similar type of finish.
tbeau
Images: 46
Postby jay » Tue Mar 11, 2008 7:32 pm
i think you would need to seal the livin' bejeepers out of the wood to get the 'hammered' finish to look like more than just paint.
and you may want to rethink black - note all the safari rover & cruisers have a white roof. solar gain cooks.
jay
Postby Steve_Cox » Tue Mar 11, 2008 7:41 pm
I looked at the Hammerite website and it seems you can paint almost anything with it as long as you do the right prep work under it. Here's what they say:
Bare Wood: - Apply a water based acrylic wood primer before applying Hammerite Hammered Finish.
Painted wood: - Abrade the painted surface to provide a mechanical key.
- Wash down thoroughly with diluted detergent to remove contaminants.
- Rinse with clean water.
- Allow to dry.
That's all there is to it. I think the hammered finish will look cool :thumbsup:
Steve_Cox
Images: 196
Postby Steve F » Tue Mar 11, 2008 7:44 pm
Hmm, I'm tempted to give this a go as well. My trailer frame already has the hammered finish so maybe carry it on to the rest of it in a silver.
Cheers
Steve F
Images: 25
Postby satch » Tue Mar 11, 2008 9:16 pm
I would do a test board first ( a scrap piece of ply). This way you can tell how it would apply, plus if you like the look. 8)
If it itches. scratch it
Rick
satch
Images: 63
Postby tbeau » Tue Mar 11, 2008 9:36 pm
yea, I was talking to a friend and he brought up the same point, he sugested white or silver. I thinkeither of those would go ok with my paint ideas.
I was kind of planing on doing this, I have a friend who sells paint,he said hecan get me some sample paint on the cheap/free.
you know some times i just want to rush and get it done, but I now I need to get more problems worked out. :thinking:
tbeau
Images: 46
Postby satch » Tue Mar 11, 2008 9:46 pm
you know some times i just want to rush and get it done, but I now I need to get more problems worked out. :thinking:[/quote]
I know EXACTLY what you mean!!
Rick
satch
Images: 63
Postby tonyj » Tue Mar 11, 2008 10:41 pm
A design for a dust collector from wood magazine used Hammerite to give a metal finish look to the wood frame, I think. If not Hammerite, it was something like it. Like Steve Cox said (and the website), proper surface prep.
tony
tonyj
Images: 160
Postby pathdoc2 » Sun Jun 08, 2008 10:26 pm
I've used Hammerite on several pieces of wood furniture for indoor use with great success.
pathdoc2
Postby Bristol Delica » Mon Jun 09, 2008 2:34 am
Hi
Have to agree with Pathdoc, I've used Hammerite on wooden furniture, both indoor and outdoor. It keys well to wood if sanded and dust free and is very weather resistant.
Best of luck.
IanJ
He who dies with the most toys, wins!
Bristol Delica
Images: 24
Postby Walt M » Mon Jun 09, 2008 7:14 am
I also have used Hammerite paint on some wood sound system road cases and it looks good and holds up well. Good Luck.
Walt
All that is needed for evil to flourish, is for good men to do nothing.
Walt M
Images: 50
Postby tinksdad » Mon Jun 09, 2008 7:26 am
One of my jobs in the before days, I worked in the body shop for the public transportation system of a large city that will remain un-named. OK.....It was Buffalo, NY. I was one of three painters spraying all the buses and vehicles. In our spare time, we experimented with all the paints. To get the desired effect from Hammerite on wood, the surface has to be sealed very very well, almost slick. Otherwise it just looked like silver grey paint. The best way to make it happen is a good base coat of a neutral color.
If your going to spray it, give the gun a good swirl every so often to keep the thinner mixed with the paint. It doesn't actually separate, it just makes the ripple effect work better.
tinksdad
Images: 155
Postby H@nk » Mon Jun 09, 2008 1:14 pm
Whe I talked to a boatbuilder a short time ago, he told me to put some epoxy-primer first on the wood, than epoxy with harder, than glassfiber with a finishing epoxy shell and at least the hamerrite, with built-in UV-filter. So that's what I'm going to do. For the costs it will be about 250 EURO's and than the cost of the Hamerrite.
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
