Lightweight Frame building
Postby toypusher » Thu Apr 14, 2005 9:39 am
Mike,
I was thinking about a welded frame (5x9) and reworked your drawing (I used Photoshop, so it's not quite right). Anyway, do you think that I would need to box the front or second crossmember (or both) to add for the welds? Or would the angle be enough. I was also thinking that maybe the crossmembers should be cut in for the square tubing of the tongue, like Bufordt suggested.
Kerry
toypusher
Images: 324
Postby mikeschn » Thu Apr 14, 2005 9:46 am
Oh for a welded frame I would keep it really simple, like this...
Images: 479
Postby toypusher » Thu Apr 14, 2005 9:54 am
Mike,
Is that 2x2x3/16 square tubing?
Kerry
toypusher
Images: 324
Postby mikeschn » Thu Apr 14, 2005 9:56 am
Kerry,
That 2x2x1/8" tubing. Only the tongue has 2x2x3/16" tubing. I have some drawings laying around somewhere. I'll see if I can find them.
Images: 479
Postby mikeschn » Thu Apr 14, 2005 4:17 pm
I'm home now... ah on Teardrop time at last!!! :o
I did wander out and take a look at the bolts holding on my axle. There are (2) 5/8" bolts on each side...
Here's what one looks like...
Now lets see if I can find those trailer plans... in a teardrop minute hopefully!
Images: 479
Postby angib » Thu Apr 14, 2005 6:10 pm
Interesting to see the word 'China' clearly cast into the trailing arm of that (Flexiride?) axle... :shock:
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Thu Apr 14, 2005 6:18 pm
Actually that's a Dexter axle with the words China cast into it... I'll have to ask Steve if China is cast into the flexiride axle...
But it's as clear as the photo I shared with you above...
When the Chinese imports replace the Fords, GMs and Chryslers in this country the transformation will be complete. We will have been assimilated!
Images: 479
welded trailer plans... sorry for the excessive bandwidth...
Postby mikeschn » Thu Apr 14, 2005 7:10 pm
Ah, after a long teardrop moment, Chell managed to find the information...
With this message you have enough information to build your own custom trailer for a teardrop...
Mike..
Images: 479
Postby toypusher » Thu Apr 14, 2005 7:15 pm
Mike,
Thanks, the supersize will come in handy for us old folks. :rofl:
Kerry
toypusher
Images: 324
Postby toypusher » Thu Apr 14, 2005 7:26 pm
It makes the whole thread pretty wide and I have to scroll back and forth. I just downloaded them and use my software to scale them.
Did the original order you made include the 13" wheels and tires or did you trade them in on the ones that you used??
Kerry
toypusher
Images: 324
Postby mikeschn » Thu Apr 14, 2005 7:26 pm
Okay, I've resized everything to 640 wide... that should be a little easier to see!!!
Images: 479
Postby mikeschn » Thu Apr 14, 2005 7:29 pm
toypusher wrote:It makes the whole thread pretty wide and I have to scroll back and forth. I just downloaded them and use my software to scale them.
Kerry
I actually didn't order the kit. I only ordered the axle and misc parts as shown on my bill.
I got the wheels from Low cost trailer supply, who had them dropshipped from Red neck trailer supply.
And the trailer was fabricated locally based on those 3 drawings...
Images: 479
Postby toypusher » Thu Apr 14, 2005 8:33 pm
Mike,
Guess I did not read everything very closely. There is a redneck place about 45 minutes from me and I probably could get most everything that I need from them and have the frame done in one of the shops around here.
Thanks again
Kerry
toypusher
Images: 324
Postby roar » Fri Apr 15, 2005 2:59 pm
Thank's for all the information,
I got the small part made with steell 2X2X3/16 angle so i can start this week-end, i wasn't able to fit the 8 feet inside the car so it will be next week for those one, tried to find place in canada for tortion axles..... 3-5 weeks delays and the can give confirmation that i will get it in time.So for now i will stay with a ordinary suspention until next tear drop :). Next car will be bigger so il will need a bigger tear drop with more option in it
Roar
roar
Postby Rowdy » Sun May 01, 2005 5:07 pm
mikeschn wrote:I'm home now... ah on Teardrop time at last!!! :o
Rowdy
