plywood spar?
plywood spar?
Postby roar » Mon Apr 25, 2005 11:06 pm
HI,
Got the hand on 30 pcs of 3" X 8' 1/2 plywood i was thinking on using urethan glue to make a 3" x 1" for my spar. Anyone used something similar?
Wife controling the buget for the teardrop so... If i want gadget (solar panel) i have to save somewhere else.
Roar
roar
Postby nickster60 » Mon May 02, 2005 8:51 am
They do this in boats for stringers all the time. I think it would work
nick
nickster60
Postby mikeschn » Mon May 02, 2005 8:53 am
My only fear is that the plywood would split when you drive screws, nails or staples into the edges.
I wonder if sealing the edges with something would make splitting less likely to happen?
Postby toypusher » Mon May 02, 2005 9:09 am
Maybe a thin coat of epoxy?
toypusher
Images: 324
Postby SteveH » Mon May 02, 2005 10:55 am
A coat of thined epoxy applied and let wick into the end grain of the plywood will definately make it stronger. We do that all the time building RC model airplanes.
I would, however, drill a pilot hole for all screws in the end grain of the ply.
SteveH
SteveH
Images: 42
Postby IraRat » Mon May 02, 2005 11:02 am
3 inches wide by 8 feet?
Is that a standard cut used for something, or did it come from waste cuts?
--Ira
IraRat
Forum Storyteller
Postby Woody » Mon May 02, 2005 3:20 pm
Pilot drill the holes first should cure the splitting problem and keep the screws from wandering as well
Woody
E-mail: [email protected]
Woody
Images: 26
Postby roar » Mon May 02, 2005 7:06 pm
IraRat wrote:3 inches wide by 8 feet?
It came from waste, they redo the floor of and old house the the stud wasn't at standart distance so by cutting 3 inch at each plywood they can screw it on the stud
roar
roar
