Dandy wrote:For those of you who asked, I got the door at Bontragers in White Pigeon, MI. They were asking $45, but when I hemmed and hawed a little about it not having a lock, they gave it to me for $30.
They have about a dozen of these left, most do not have locks (meaning they are missing just the outside key cylinder). They are in good shape with just very minor blemishes. Most are gray and a couple are white. Also, l should mention that all of the ones that are left have a door catch installed in the upper right hand corner - the one I bought does not. I wasn't sure if there would be anywhere on the trailer to mount the mating part of the catch.
It looks to me that painting them would not be an issue. The lock on the other hand may be a bigger problem to solve.
Dave
Dave
WarPony wrote:Dave, am I to assume that you are going to insulate with 3/4" foam board in the spaces that are cut out in the walls? If so, DON'T USE THE 3/4" PLYWOOD!!!!!! It's not a true 3/4" thick......... it's 23/32" thick.
It doesn't sound like that much but you won't be able to smoosh the foamboard without a lot of work.
Jeff
halfdome, Danny wrote:If you have access to an overhead wide belt sander you can run the foam down to 23/32". That's what I did.
WarPony wrote:halfdome, Danny wrote:If you have access to an overhead wide belt sander you can run the foam down to 23/32". That's what I did.
(mummbling in a low voice)...you gotta be kidding me!! Is that made up, that sounds made up....![]()
Jeff
