by Nitetimes » Mon May 02, 2005 11:02 pm
When I was building trailers I would generally leave about 3.5-5 inches above the tire for torflex axles, for springs you just measure from the top of the axle (if it's above the spring) to the bottom of the frame and add a 1/2" to that # for fender clearance. You need to be sure that you have a little more clearance between your fender and tire thanthe axles can move up and down otherwise you tend to burn the paint off of the fender when the trailer bounces.
Rich
- Thomas Jefferson -
