Guy wrote:Dear All,
Something I have never understood all this time is the typical plans say to put the doors on after you have placed the sides up and the spars on the roof etc. There are too many chances, as you attach the sides to the frames, the spars and the roof and all the movement that ensues, to throw in a little twist. It is so much easier to place the doors in, at least temporarily, to limit such movement. Remeber this is not similar to a house frame where you get to shim the door frame and then place moulding around hiding all the shims.
toypusher wrote:Tom,
According to Kevin, you have to have the door opening trimmed in aluminum before sizing the door properly or it will not fit right. Just something to keep in mind.
Kerry
larryl wrote:I installed black radius cornered windows from TJ Trailers. The space between the window and inside skin was covered with black vinyl baseboard. It's normally used on a wall after tile or sheetgoods are installed. I think it turned out nice.
Larry
