brian_bp wrote:looped wrote:i plan to run these...
...and one of these on top
just hoping this isnt too much overkill
Is the one on top intended as a Center High-Mounted Stop Lamp (CHMSL third brake light)? If the trailer has combined stop/turn lamps (not separate turn signals), then a central brake light will need a converter circuit to run it properly, so it doesn't flash with the turn signals.
I don't think a CHMSL is overkill at all... people expect them now, so a vehicle without is less noticeable when it brakes.
ahh i didnt think of that. just got the 4 wire adapter (t-one connecter) in the mail today and after looking at the wiring i see you are correct..
well i guess i will nix the chmsl and rely on the pair of lights for the rear. according to the product info each of the tail lights has 40 led lamps in there so that should be enough.
for the plate i am thinking the little led bulbs in the fixing bolts idea and using an old 55-56 chevy front plate mount for it since it would be hidden from view.
