Who needs a sprinkler system when ya got...
BEER
Mary K wrote:Juneaudave wrote:After following this thread, I'm pretty sure now that the SlumberMAX will burn to the ground due to my wiring job!!! Anyone ever install a sprinkler system in a Tear???
OH GOSH!! Dont give these Nutters here anymore ideas!!!![]()
Mk
Miriam C. wrote:[.
BobHenry![]()
and if you shake it up you don't even have to stand up to do it.
bobhenry wrote:Miriam C. wrote:[.
BobHenry![]()
OH NO ! alcohol abuse
you drink it 1st spray later as needed
If using 3 wire for a 12v system, I would recommend using the green wire (Ground) for your ground lead (normally black in two wire) and then use the white wire for your hot/A+ lead (usually Red in 2 wire), this makes it easier to remember as it is similar to the AC wiring setup. hope this helps some.
Miriam C. wrote:...in your auto you will have red and black. On your TV to TD wiring you should have brown, green, yellow and white (ground)
If everyone uses the same standard then when someone buys or inherits a TD they will not have electrical issue that are confusing...
chorizon wrote: A little search yielded the following max amp/wire gage:
10G:55A
12G:41A
14G:32A
16G:22A
18G:16A
bdosborn wrote:chorizon wrote: A little search yielded the following max amp/wire gage:
10G:55A
12G:41A
14G:32A
16G:22A
18G:16A
That chart is way high for typical wire you'll find at the home center. This is more representative of typical (THHN) wire ampacity, its from the NEC 551 section on recreational vehicles.
Table 551.10(E)(1)
Wire Size (AWG) : Ampacity
18 : 6
16 : 8
14 : 15
12 : 20
10 : 30
