WarPony wrote:I keep reading on Dexter's website about 22* up, 22* down, 0*......... Is there a way to adjust the start angle or do you tell them what you want and hope it's right?
Jeff
WarPony wrote:How the heck do you determine which angle to go with? I imagine it has to do with wheel size, trailer height and the weight.
Jeff
Here's what I've found using Dexter's #9 side-mount axle, rated at 1,000# under a 750# trailer with 195/75R14 tires:
10º Up Starting Angle (my standard) - 12-13" ground-to-frame clearance.
22.5 Up - 10-11" clearance
0º - 14-15" clearance
10º Down - 16-17"
22.5º Down - 18-19"
WarPony wrote:Okay, I get the "no load" dimension but what is the difference between "full load" and "shock load"?
Jeff
grant whipp wrote:halfdome, Danny wrote:Hi Grant,
I went to 6-Robblees in Tacoma today and we removed a wheel to do some measurements and it seems what they made for an order is probably correct, but I'll run it by you (the expert).
Axle: Model 9, Spindle standard, grease
Combination: single, hubface 73.50, outside of bracket 57.50
rubber capacity 1600
Arm Brackets: Arm 6, Start angle, 10 degrees up, Profile - high
Orientation: Standard orientation
Hardware: A/P-161-00 Top mount
Brakes: K23-047-00 LH Electric Size 7 x 1 1/4
Hubs: 008-257-05 Bolt circle 5 on 4.5 Capacity 2200 #/pair
H-D, 1/2 Studs, Grease
Wheels: Size 15 x 5JJ Capacity 1000 #/each Wheel offset: 0.50 Inset
Axle capacity (each axle) 1600 lbs (Excluding rims, wheels and tires)
G. A. W. R. (each axle) 1600 lbs. (Including rims, wheels, and tires)
Entire Running Gear 1600 lbs. (Including rims, wheels, and tires)
Since I am a two fingers typer, I got out the big guns......Jane typed this for me (and he better not forget it, either!!!!!! hi from Jane)
Thanks,Danny
Hi, Danny! Jane, too ......! (is Danny's arm in a sling again, Jane, or do you need to send this boy to typing classes ...
...? Like I'm one to talk ...
... that's me right there, all thumbs ...!)
Looks pretty good to me, Danny! A couple of concerns I have though, are:
1) assuming you are building a 5' wide tear again, did you specifically request that the trailing arms be no less than 61" apart?
2)Re: hardware/mount type ... are you planning to weld your axle to the frame, or do you have mounting plates that you will be bolting the axle to? I typically spec a "side mount" and get the mounting brackets that I weld to the frame, and then just bolt up the axle ... makes for much easier replacement if there's ever a problem.
Two more things to think about:
1) Wheels - see if you can find 15x6s with 1-1/2" inset (positive offset, puts the tire closer to the body) ... I like the beefier tire on heavier trailers.
2) Hubs - unless you are going for the baby-moon hubcaps on chrome steelys again, think about the EZ-Lube hubs ... just pull the rubber gromet out of the grease cap, affix grease gun, and pump a couple of good shots of grease into the hub every year ... no need to get your hands greasy re-packing the bearings!
Oh, yeah ... regarding the "Arm Brackets": I've got no clue what they're talking about when they say "Profile - high" and "Orientation: Standard orientation"! Not something I've ever run across ......
Anyway, anxious to see your new project! I'm going to try to make it to the NW Spring Fling in Morton this May ... will you have it done by then and there?
Good Luck with it all, and as always ...
CHEERS!
Grant
