What the best way to weather proof the underside of the trailers plywood floor?
Just pain roofing tar? Will I need some way to heat it up?
Or is there another product that is easy to use and something I can pick up locally?
Thanks
WarPony wrote:Good call, Timbo!! Steve, I used the asphalt emulsion on my Jim Dandy build and it worked good. I think the key to ANY of this stuff is it will only get as messy as you let it. Using rollers, I think, is going to slop more than a brush will. I used a brush and applied two coats so the mess was less than I expected it to be.
It looks like the Tractor Supply stuff is oil-based, too so it will soak into the wood, that's a good thing. Just be sure to pay special attention to the edges of the plywood and apply a bit more so as to fill any voids.
Jeff
Alphacarina wrote:I just used 3 coats of oil based primer on mine - Expect the floor will outlive the trailer
Don
