Has anyone started a TD with one of these?
Postby asianflava » Mon May 12, 2008 11:03 am
A couple folks have used 3500lb axles on their "offroad" trailers, but they used regular axles instead of torsion axles. Even though they used a heavier axle, (more durable) they reduced the number of leafs in the spring pack so that the trailer would ride better.
asianflava
Postby angib » Mon May 12, 2008 4:04 pm
If you fancy, and have got, an overkill frame and the means to easily tow it around, then using it isn't going to be a big problem. But the axle is different.
It's tempting to look at 3500lb axle and think it's twice as good as a 2000lb axle, when really it's not even as good. Put a 1000-1200lb typical teardrop on a 3500lb axle and you'll get no suspension movement at all. The axle will last forever and never break - but it will beat the teardrop body, and its contents, to pieces because road shocks will be transmitted straight to the body.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Alphacarina » Mon May 12, 2008 4:32 pm
DJBear wrote:I never said I was planning on building a 3500lb teardrop
Then if you're going to use a torsion axle, you'll want to get one rated at the approximate weight of your finished teardrop - Not 3500 pounds
With a spring axle, you can sort of 'make do' by by removing a spring leaf or two but a 3500 pound torsion axle isn't good for much except for use on a 3500 pound trailer
It's a good looking trailer - You can use it to haul a small car or tractor but it's not much good as a starting point for a lightweight trailer
Don
Alphacarina
Postby DJBear » Tue May 13, 2008 1:39 pm
Okay, everyone... and thanks... :oops:
Back to the ol' drawin' board :thinking:
DJ Bear
"Start every day off with a smile and get it over with." --W.C. Fields
DJBear
Images: 11
