clean bearings.
place protector in dust cover bore.
drive protector in with hammer and block of wood
fill unit with grease gun
Comments? I know you would still want to periodically clean and inspect the bearings.
angib wrote:Can you get at the bearings after you've driven the protector in with a hammer? This looks like a one shot deal - if the bearings go, isn't the whole axle scrap, because you can't get at the spindle nut to take the hubs off?
Andrew
bobhenry wrote:
It look like it simply replaces the dust cap . You drive it on also and just wiggle it loose with pliers to remove it . I am sure that is how this contraption works.
Nitetimes wrote:That is how it works but I have found that once you remove them and re-install them they tend to be a bit too loose and end up working themselves out of the hub. I've actually had to duct tape them back in after a seal replacement so the customer wouldn't lose them on the way home.
Don't like those things, seen them cause way too many bearing failures.
BrwBier wrote:Periodically greasing the bearings on a teardrop is totally unnecessary. Has anyone owned a car before front wheel drive? How often did the bearings on the front wheels require service.
Brwbier
nikwax wrote:good discussion on these bearing buddy things. As they are unopened, I'll return them, seems like they aren't going to do anything for me that regular maintenance wouldn't, plus they'll add some overhead that I don't need.
bobhenry wrote:After all duct tape just screams tacky workmanship !
nikwax wrote:BrwBier wrote:Periodically greasing the bearings on a teardrop is totally unnecessary. Has anyone owned a car before front wheel drive? How often did the bearings on the front wheels require service.
Brwbier
I owned several rear wheel drive cars, now have a 4x4 truck, all require front wheel bearing lubrication at regular intervals. 30k on my truck, I think it was 18k on the VW's. Oh, my BMW motorcycle with shaft drive has a several bearings in the rear drive that need periodic replacement. Much better to replace them before they fail than get towed.
I completely disagree that bearings don't need regular service. At the very least I'd want to look at them periodically to make sure nothing is amiss. Any bearing can fail.
BrwBier wrote:Periodically greasing the bearings on a teardrop is totally unnecessary. Has anyone owned a car before front wheel drive? How often did the bearings on the front wheels require service. Bearing buddies were designed for boat trailers, they are ment to give a shot of grease when coming out of the water and are ment to expell the water past the rear seal.
Brwbier
BrwBier wrote:Put the cotter pin in and the dust cap on and forget it for two years.
