Marilyn
dreadcptflint wrote:Do you have a better shot of your sun? I can't make out what you did with left hand side.
mandy wrote:How do you do the windows?
Looks good, I hope you do not mind if I steal some window ideas.forestfrog wrote:Thanks everyone for the very kind compliments and encouragements, they're very much appreciated (and will help keep me motivated, LOL)!!
The two suns came from the garden center at Lowes. I sanded them down, painted them 'hammered copper', and drilled dozens of mounting holes. They're attached to the walls with 5/8" smooth hex head wood screws. I do wish the 'curls' went all the way around, instead of half/half though.mandy wrote:How do you do the windows?
The window and porthole frame are one piece (hinged to open upward) with a rubber seal sandwiched between the porthole frame and the surface of the door. There's a threaded insert hidden under the bottom 'button' on the porthole...a knob with a threaded rod screws into the insert from inside the cabin and pulls the window tight against the door to compress the seal. Sorry, that's probably as clear as mud, LOL!I used a fine grit abrasive sponge to 'etch' the moon on the window...
All of the hardware for the 'lock':
If you popped off the bottom button on the porthole this is what you'd see from the outside:
Reverse:
Plain wooden cabinet knob with a threaded insert added:
tinksdad wrote: TD's and caching just seem to be meant for each other, especially on those weekend long cache runs!!
Mauleskinner wrote:Am I seeing that the tongue box is accessible from inside the tear?
