Currently I am not towing any rig. I am thinking the best off the bat would be a seven pin as most modern are wired for that, if I need to charge a battery, run a brake system and plus it's easier to get an adapter and size down to a four pin if I go retro. His service guys are saying that if I go with a seven pin then I would need a brake controller if I go with the seven pin. The vehicle is a 00 Ford Exploder.
Should I stick to my guns and get the seven pin?
