Your outcome on your roof skin.
Postby madjack » Fri May 30, 2008 4:04 pm
Spad, I had been wondering about your corroplast...if you are talking about doing the luan as a woody or painted finish, then yes, you would glue it down...I would seal it all with epoxy and then paint with a topside paint or clearcoat for a woody look..........
madjack 8)
Postby Spadinator » Fri May 30, 2008 4:06 pm
Copy that Madjack....Thanks.
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby Roly Nelson » Mon Jun 02, 2008 12:45 am
I glued and nailed my first layer of 1/8" laun onto the roof struts, with the good side down. Then added a second layer, good side up, using panel adhesive liberally along the edges, which were also nailed down and sporadically shot some glue between the sheets of plywood. No problems so far.
Roly :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
