by Dale M. » Sat May 31, 2008 5:32 pm
California and most other states "require" at least the federal minimum standards.... Whether or not you follow this is your choice....
Here is most definitive requirement for clearance light..
http://www.dmv.ca.gov/pubs/vctop/d12/vc25100.htm
IF trailer is over 80 inch wide it IS required to have clearance lights...
Yes, 80 inches is trailers widest point probably at outside of fenders if so equipped.
Here is "alpha" index to CA DMV.... Probably easiest way to find anything...
http://www.dmv.ca.gov/pubs/vctop/vc/vc.htm
Dale
