HossHoffer wrote:The recommendation for NiCads has been updates in the last few years. Overcharging, slow-charging and overheating are the worst problems. Voltage depression (memory) is seen very infrequently and usually has to have a very repeatable pattern of charge/discharge over a long period. It is now considered ok to charge a NiCad at will, watching out of course for overcharging and overheating.
looped wrote:I have seen these chargers called battery tender II they seem to act like a peak detection charger. are they good to use? the price seems right for them.
Hinermad wrote:looped wrote:I have seen these chargers called battery tender II they seem to act like a peak detection charger. are they good to use? the price seems right for them.
I've never used one so I can't speak to how well it's made, but the idea is that it monitors your battery and switches from full current charging (which will charge your battery quickly) to float charging (which keeps a full battery full without overcharging it) automatically. It's what you'd want to use if you have a battery that will stay on the charger almost all the time and only get used occasionally. A lot of motorcyclists use them to maintain the charge on their bike batteries through the winter because they can just connect it and forget it.
You do need to make sure you use the right tender for your battery type. You don't want to use a tender for lead-acid batteries with Nicads, for example.
Dave
