A teardrop trailers balance is quite heavy on the tail, so to compensate we move the axle back. Now My thoughts on welding a trailer together that was engineered to be bolted together, is use locktight and torque the bolts like listed in the instructions. If length of the frame is an issue, there is a way to stretch it, and still bolt it together.halexanderwilhelm wrote:With gas prices what they are, and keeping in mind my budget I think that for this project I'm going to stick with the smaller trailer from redtrailers.com versus their optional teardrop 5 x 10. I like the idea of being able to tow the camper with a smaller vehicle (I have a Honda Element) and I don't want to overload the vehicle with a large tow weight. Two things that I've heard about on the forum was something about tongue weight/axle weight ratio and balancing the trailer, and also welding the frame together vs leaving it bolted together. Any recommendations and what are the benefits?
Torque specs off the top of my head I do not know, worked with bolts most of my life. Too tight and problems arise (read you do not need a three foot cheater bar to tighten), and too loose is a problem also. Most bolts in my trailer where installed at least twice, and I will not trust plastic lock nuts but once.jp03 wrote:Never saw no specs on the bolt torque? My red trailer was assembled, so no instructions came with it. Now my HF trailer has no torque specs at all listed. Was wondering what they should be. Does lock tite effect the plastic of the locking nuts?
BPFox wrote:These small utility trailers are a great place to start but are not engineered to be platforms for the type of trailers being built here.
angib wrote:......................................................................
Agreed - these utility trailers are mostly over-engineered for the job of carrying a teardrop body around. Built properly, a teardrop body is self-supporting and the only bits of the utility trailer that are really needed are the tongue and the suspension/axle - the rest of the frame of the trailer is just a portable workbench to build the teardrop on.
Andrew
