by IraRat » Wed May 18, 2005 2:04 pm
This is a tough one, but...
Can you get a hold of a regular slide projector?
You can print your profile to a piece of acetate/transparency (sold at Office Depot) that's designed for either your ink jet or laser printer. You then simply have to output it at 35mm transparency size and stick in a plastic blank slude holder. (If you have problems finding them, I'll MAIL you some. I know I have a bunch in a box somehere.)
I forget the exact 35mm size because it's been so long since I touched film, but how to do this depends on the program you're using to create the profile. However, it's pretty easy to do.
You can also output like 20 of them on a single page, at different dimensions. Again, depending on the program you're using.
Now just turn out the lights, get your popcorn, stick the wood against the wall PERFECTLY perpendicular to that wall, and start tracing.
Not sure if I would want to do it this way, but to each his own.
--Ira
