tearhead wrote:My question relates to size. The existing (exhaust) fan is built into the shelf area above our feet and it vents into the galley. If the windows are cracked open a bit, it works great, but then it hasn't been that warm out. I'm thinking I would like to supplement the existing fan by suspending the second fan from the ceiling, to get more air moving through (we only have the two windows that are in the door). Of course, then we might bump our heads on it.
I'm thinking I like the size of the smaller one, since it only needs to supplement the built in fan. But is it too cheapo?
48Rob wrote:Hi,
Guess I need to go take a picture...I'll try to do so soon.
As I recall, I used a stainless steel band clamp to hold the motor portion, then riveted the clamp to an angle bracket.
The angle bracket was screwed to the brace that holds the crank to open the vent.
Rob
dh wrote:
What type of switch would I use to get fancy and put a fan speed controll on the wall?
