Hatch Side Moulding Question
Postby Classic Finn » Sat Jun 14, 2008 7:49 am
Id like to know what you folks used to fasten the hatch - side moulding?
If I use screws they will come all the way through.. :thinking: :thinking: :thinking:
I was thinking of using pop rivets but thought to ask first before I persue it.
Classic Finn :)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby toypusher » Sat Jun 14, 2008 7:52 am
Heikki,
I used pop rivets to fasten the moulding on the sides of my hatch. Not sure about pics, but you might be able to see some in my build photos.
toypusher
Images: 324
Postby Classic Finn » Sat Jun 14, 2008 8:54 am
Thank You Kerry
Is there a certain type of rivets or is it just a matter of preference on this?
Classic Finn ;)
Classic Finn
Images: 146
Postby toypusher » Sat Jun 14, 2008 9:51 am
I just used what I happened to already have at the time. Don't recall now just what they were!!
toypusher
Images: 324
Postby madjack » Sat Jun 14, 2008 1:28 pm
Heikki, we used pop rivets as well...we sandwiched the ply with the molding on top and a flat AL strip on the bottom...used a flat headed rivet and put them in from the underneath side, so they wouldn't interfere with the seal and the protrusion on top was covered by the insert that goes in the top molding....
madjack 8)
p.s use your SikaFlex liberally!!!!!!!!!MJ
Postby Classic Finn » Sat Jun 14, 2008 1:49 pm
madjack wrote:Heikki, we used pop rivets as well...we sandwiched the ply with the molding on top and a flat AL strip on the bottom...used a flat headed rivet and put them in from the underneath side, so they wouldn't interfere with the seal and the protrusion on top was covered by the insert that goes in the top molding....
madjack 8)
Thank You Madjack.. I had plans on going through the top ... but good thing now I know to go from the bottom instead. :thumbsup: :thumbsup:
:thumbsup: :thumbsup: Gotcha thank you ;)
Yes plenty of Sikaflex on hand too. 8)
Classic Finn
Images: 146
Which raises another question
Postby Creamcracker » Sat Jun 14, 2008 3:13 pm
How do you "transition" the edge molding from the main body roof/edge into the hatch area? Do you just cut it off and leave an ugly almost unfinished break? Is there some sort of end cap that fits to close off the edge molding? On one example I looked at it seemed as though the center plastic strip covering the screws was continuous onto the hatch area. Any thoughts?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby madjack » Sat Jun 14, 2008 7:25 pm
Phil, I looked and looked but couldn't find any specific pics...if follow this link...
http://picasaweb.google.com/madjack53/Photoshoot
...and scroll down, there are a few pics, fairly close of the bottom, front finished trim...what we did is cut the insert an inch or so long, trim down the edges a bit and folded it under the rest of the insert...it gave it a nice smooth edge and basically filled the gap under the insert...they actually make a cap for the end of the insert molding but you havvta end the molding short to have room for it to fit....
madjack 8)
Postby Airspeed » Sun Jun 15, 2008 2:13 pm
I used screws and T nuts, they hold very well and end up flush on the underside. Aaron
Airspeed
Images: 16
Postby planovet » Sun Jun 15, 2008 2:26 pm
Nice pics madjack, that is a sweet looking teardrop. What did you use to trim the inside cabinets?
ImageMark (& Cindi)
planovet
The Cat Man
Users browsing this forum: Google [Bot] and 5 guests
