connecting metal roof to walls
Postby calumet » Fri Jun 20, 2008 8:57 pm
How is a sheet metal roof attached to plywood walls? I have searched but can’t find it. Also, can it be glued to the spars and insulation or must it be screwed?
calumet
Postby mikeschn » Sat Jun 21, 2008 6:17 am
I assume you mean aluminum.
I used gorilla glue to glue the roof skin to the spars and wall edges, and then I used duct tape to hold it in place till it dried (overnight) Then I used aluminum angle to make the connection permanent. I know that the glue joints eventually broke. But with the aluminum angle and screws, I was basically floating the roof skin.
Some one else here might have a better idea for glue.
Here you can see the screws that I put in the aluminum angle.
Postby calumet » Sat Jun 21, 2008 8:17 am
Thanks, Mike. That is what I was looking for.
No, I meant sheet metal. Aluminum is too pricey and I have 5’ sheet metal available through a friend that does AC duct work.
I wanted a 60” floor for a queen mattress which put my outside wall width at 63” with ½” ply walls, insulation and paneling. If I skip the insulation, at least to mattress height, then I would need a 59” floor for the 5’ sheet metal roof, correct? It covers to the outside wall edge when installed with the angle?
Did you seal under the angle?
Thanks.
calumet
Postby mikeschn » Sat Jun 21, 2008 8:21 am
Yes, I used a polyurethane calking to seal under the angle.
It looks like you have 1 1/2" thick walls...
Working backwards, 60" minus 1 1/2" walls is 57" for the floor. that's 3" wider than a full size bed, and 3" narrower than a queen sized bed.
calumet wrote:I wanted a 60” floor for a queen mattress which put my outside wall width at 63” with ½” ply walls, insulation and paneling. If I skip the insulation, at least to mattress height, then I would need a 59” floor for the 5’ sheet metal roof, correct?
Postby calumet » Sat Jun 21, 2008 11:00 am
My walls are ½” (15/32) plywood that are going to be attached to the outside edge of the floor. I was planning on attaching ¾” insulation and 1/8” paneling to the inside of the wall. Actual wall would then be 1-3/8”, the extra 1/8” was just wiggle room.
However, the dilemma lies in the 5’ sheet metal roof. In order to overlap the ½” outside walls, the floor would have to be 59” and that is with out insulation. Since the mattress would act as insulation, I thought I could start near the mattress top.
But, then, we are still looking at 59” for a 60” mattress. Perhaps I could use an inflatable Queen.
How do others manage a queen with 5’ roof?
calumet
Postby mikeschn » Sat Jun 21, 2008 1:17 pm
In a word... "foam". Knox Foam to be exact. They end up buying cushions to make a near queen sized bed!
Postby madjack » Sat Jun 21, 2008 1:55 pm
C, we build with a solid 3/4" wall and our overall outside measurement is 59.5"s...this allows a little "wiggle room for roof attachment(60"wide material)...this leaves 58"s for inside measurement...we use a foam mattress which we get custom cut from an eBay store..."thefoamguys"...around 150 bucks for a 56x78x4" furniture grade(2.5#) foam mattress...which my wife and I(6'3) and out two mutant Chihuahuas find luxuriously roomy.....
madjack 8)
p.s. we float our skins, relying on the trim and such to anchor them in place...we do shoot a couple of staples along the edges to hold in place until the trim goes on......MJ
Postby calumet » Sat Jun 21, 2008 3:12 pm
Thanks guys!
Glad you mentioned the 59.5" instead of 60".
I'll contact the foamguy.
calumet
Postby madjack » Sun Jun 22, 2008 7:31 am
http://stores.ebay.com/The-Foam-Guys if you don't see what ya want, give 'em an email and they will probably doit up for ya......
madjack 8)
Users browsing this forum: Google [Bot] and 4 guests
