hope this helps del
2bits wrote:Grant is a good source for seals and trim and the little things that we go searching for all the time. I think I got most if not all of my answers right here in the forum! I asked alot of questions, but I learned ten times as much just looking at photos and reading other peoples real world experiences!
del wrote:Here is a drawing given me when I built my doors. Your wall will be thicker and strait up and down. The black is a seal, the red a rain gutter.
hope this helps del
2bits wrote:Smooth doors! I like that wood grain too.
Wow, I thought of something good enough to swipe! Awesome!I didn't want any of my frame to show, and a rabbet just seemed the simplest way. I actually had to cut it twice, I don't know what I was thinking the first time, but I didn't cut it deep enough, the second cut I believe was right at 4" up from the bottom. That actually hangs lower than needed, where I had to cut an axle notch, but I had to cut that high for the profile to line up with the front and rear of the floor correctly because the length of the floor stays the same but the length of the route line changes with the depth of the route, so keep that in mind so they are the same when you install! I just laid my wall flat on it's side and pulled it over the edge equally until the profile end met the floor and I knew that was how deep to cut. You may not have this problem at all, but that's what I ran in to.
Looking good!
Miriam C. wrote::applause:Wonderful grain on the wood.
Looks like your helper is doing a great job of it.
2bits wrote:Is that the only thing you did? No stain? It looks GREAT! !! I would like to come by sometime you are putting a coat on if it is ok. I've never worked with this stuff. I work up in Frisco.
