Don't waste money on a radioshack junk adapter.
Get a LM317T. Here is the link:
http://www.radioshack.com/product/index ... 062601&cp=
Then you will need 2 resistors to set the voltage.
Go to:
http://www.cpemma.co.uk/317calc.html
In the top row of the calculator enter 4.5 for the volts, then enter a resistance that you can find at radioshack. I used 100 for resistor 1 and the calculator says 260 ohms for resistor 2. This gives an output of 4.5 volts.
Then connect resistor 1 between the "out" and "com" pins on the LM317T.
Next connect resistor 2 between the negative side of the battery and the "com" pin on the LM317T.
Done. For a few dollars you have 4.5 volts.
A resistor will only drop the voltage relative to the battery voltage. So when your battery drops to 11 volts for example the lowered voltage will probably be about 4 volts instead of the required 4.5 volts.
The best part of this regulator is that it will always put out 4.5 volts even if the battery voltage drops.
It can handle a load of up to 2.2 amps I think...but I wouldn't trust it at over about half that load.
If you can't solder I can build it if you send me a few bucks for parts.
