http://tnttt.com/album_ ... er_id=6339
Miriam C. wrote:Your td is only 4' wide or is it 5'? You can get Baltic Birch in 1/8" at 5x5. Just look for football patches. you won't like the results if you get one on the bend. I used 1/8" Birch that was supposed to be plywood but ended up with a paneling. Worked great on the ceiling inside. Not good for the roof outside. If I had epoxied it might have worked better. Now I get to paint.........
SkipperSue wrote:I used 1/8" fake pine paneling in mine. I took the inside curves really easy. I got it from Lowes.
tinksdad wrote:... I was looking at the FRP (fibreglass reinforced panel) for the outer roof skin. I'm going to go back and if I can find anybody who works there with any kind of information, I will decide whether or not to use FRP for the outer roof skin. If I do decide to use it, it will end up being painted the same bright red as my frame and tongue box ...
RoskoPcoltrain wrote:Miriam C. wrote:Your td is only 4' wide or is it 5'? You can get Baltic Birch in 1/8" at 5x5. Just look for football patches. you won't like the results if you get one on the bend. I used 1/8" Birch that was supposed to be plywood but ended up with a paneling. Worked great on the ceiling inside. Not good for the roof outside. If I had epoxied it might have worked better. Now I get to paint.........
It is 4' but I was originally going to use 1/2 inch for the sides. I decided to go with 3/4 but didn't change my measurements so now the outside width measures 48 1/2. Small mistake and a lot more wood.![]()
Thanks for your help. I finished my galley today and started working on the doors. I will probably have more questions before the week is over!
