I'm marking my walls for the spar placement and my frame/floor combo calls for the first spar in the front to be 1/2" closer to the bottom of the frame than the GenBen plans call for.
If I keep the same distance between spare as spec'd in the plan but have them offset by the 1/2" variation i need, will I be OK? It looks like the critical part of spar pacing is to avoid a spar at a liner panel seam and to allow proper spacing for the roof fan. Are those the basic critical considerations? I don;t want to mess this up!
Geoff
