Does this 1954 benroy wheel turn
Postby TD_Dodger » Fri Jun 27, 2008 9:12 pm
can anyone tell me if this wheel suppose to trun or is it a fixed wheel. so far i know the wheel rolls but i cant turn it. i dunno if it is because of the rust.
http://tnttt.com/album_ ... c_id=37427
TD_Dodger
Images: 61
Postby Gage » Fri Jun 27, 2008 11:20 pm
Yep, it should spin around and around. What you may have to do is stick a jack stand under the tongue and and remove the wheel unit (not the whole jack). Satcherate (ms) it with WD40 to try and brake loose the roller balls (bearings). That will be a hard jack wheel to replace without replacing the whole jack unit. (take your time with it)
Image Image Image
Gage
Images: 28
Postby Muggnz » Sat Jun 28, 2008 2:11 am
Using a fluid Rust remover before WD40, CRC or penetrating oil might work. Especially if left overnite.
Heat might also help.
Muggnz
Crybaby
Images: 34
Postby BrwBier » Sat Jun 28, 2008 6:35 am
I have had luck getting rusted things apart or moving by using a good penetrating spray and sealing the part in a plastic bag for a few days or so.
Brwbier
BrwBier
Images: 100
Postby emiller » Sat Jun 28, 2008 7:43 am
This is by far the best stuff I have ever used on rust, I believers when others try it. It's made by ZEP manufacturing. I have sprayed really rusted parts before that I can't move with a wrench and come back the next day and can almost take the rusty part off by hand.
emiller
Images: 157
Postby jhjspecks » Sat Jun 28, 2008 10:28 am
from a saltwater guy, I would not use WD-40 but instead Corrision X spray. Same stuff, but it does not have water in the spray.
jhjspecks
Postby Dale M. » Sat Jun 28, 2008 11:34 am
While everybody is touting their favorite rust breaker...
I like PB Blaster....
Dale
Dale M.
Images: 18
Postby Gage » Sat Jun 28, 2008 12:03 pm
Dale M. wrote:While everybody is touting their favorite rust breaker...
Dale
Yep. that's what I use and was going to say but couldn't think of it or find the can last night. :thumbsup:
Image Image Image
Gage
Images: 28
Postby Mauleskinner » Sat Jun 28, 2008 1:55 pm
I hear the Sledge-O-Matics are on sale...makes it "just that easy"! :D
David
Mauleskinner
Postby TD_Dodger » Sat Jun 28, 2008 5:33 pm
man you guys are a great help thank god i found this place
TD_Dodger
Images: 61
Postby Jiminsav » Sat Jun 28, 2008 6:55 pm
PB blaster can loosen up a virgin..
but since your not dealing with a virgin, it will work on that old part too. :D
Jim in Savannah
Jiminsav
Images: 40
Worked for me...
Postby DrJerry » Sun Jun 29, 2008 1:13 am
Dexron and kerosene in a bucket.
Set wheel in bucket.
Go away for a few days.
Come back and whack it with a hammer.
Repeat as necessary.
Jerry
Watch and laugh as an Engineer with an advanced degree attempts to build a Tiny Travel Trailer:
http://www.angelfire.com/blog/weekender ... weekender/
DrJerry
Postby TD_Dodger » Tue Jul 01, 2008 12:42 pm
UNFORTUNETLY I FOUND OUT NOT TO WACK IT WITH A HAMMER I DENTED PART OF THE WHEEL. YOU CAN TELL ONLY IF YOU LOOK CARFULLY. I BOUGHT THAT SPRAY AND LET IT SIT FOR ANOTHER DAY SO SEE WHAT HAPPENDS.
TD_Dodger
Images: 61
Postby SkipperSue » Tue Jul 01, 2008 1:05 pm
This is my favorite. I learned about it when I started getting into gunsmithing.
http://www.kanolabs.com/google/
Skipper
SkipperSue
Images: 114
Postby Nut » Tue Jul 01, 2008 2:06 pm
Dale
Yep..... great stuff. We use it at work all the time.
Nut
Images: 6
