Frame
Outside
Inside
Galley
So what's everyone think???
(Edit) I've moved the air conditioner to below the inside cabinets in the bulkhead wall, but for some reason the picture won't refresh
mikeschn wrote:Not bad.
I see you insist on knocking yourself out at night. That's fine.
I don't see any room for the roof. Spars are typically 1 1/2" and the skins are typically 1/8" on the inside and a couple layers of 1/8" on the outside.
I can't quite make out that gray thing by your feet. Is that an electric heater?
ScubbaStv wrote:Well I was hoping to have full support under the air conditioner so that there would be no sagging. If it is not going to be a problem, then that's a great idea. A full cabinet on th front would be nice but also add more weight and I am going to pull it with a 95 Jeep Wrangler with a 2.5 4 cyl, 5 speed. I also only have a 1.25" hitch receiver instead of 2". I'm trying to keep it as light as possible but have enough room... Kinda a catch 22 you know?
Return to Generic Building Plans
