T-moulding weather stripping help!
Postby benzu » Wed Jul 02, 2008 5:09 pm
What is the proper way to seal the doors? I bought the t-molding from Grant for the doors, where is the best place to put the weather stripping. The gap in my doors ranges anywhere from 1/4'' to 1/8'' nothing on this trailer is the same.
Grants drip rail??
What is the best way to bend the radius around the door?
Thanks,
Mike
benzu
Images: 119
Postby mikeschn » Wed Jul 02, 2008 5:15 pm
The weather stripping should go right there where the thumb is in this picture.
And the drip rail, I just bent it gently by hand.
Postby benzu » Wed Jul 02, 2008 5:19 pm
Your door looks about the same as mine what thickness of weather stripping did you use and what kind.
mike
benzu
Images: 119
Postby mikeschn » Wed Jul 02, 2008 5:25 pm
I don't remember the details, but here is a better picture. I got the weatherstripping from Home Depot.
Also, normally the weatherstripping would only go on the door, not on the body like I have shown in this picture.
Postby benzu » Wed Jul 02, 2008 5:29 pm
THANKS MIKE
benzu
Images: 119
Postby planovet » Wed Jul 02, 2008 5:46 pm
mikeschn wrote:The weather stripping should go right there where the thumb is in this picture.
Mike, what did you trim the door opening with in this picture??
ImageMark (& Cindi)
planovet
The Cat Man
Postby mikeschn » Wed Jul 02, 2008 6:32 pm
I trimmed it with angle on each edge, with a piece of alum. underneath. The angle had one leg ripped down to about 1/8". I don't know if I took a close up picture of it, and I can't check today, since I left my data drive at work. :cry:
edit: I restored this picture from backup. It shows the trimwork a little better. And oh yea, it's all caulked up too!
Postby planovet » Thu Jul 03, 2008 11:23 am
Thanks Mike!
ImageMark (& Cindi)
planovet
The Cat Man
