Exterior Door Hinge
Exterior Door Hinge
Postby planovet » Wed Jul 02, 2008 6:31 pm
As anyone used this hinge for their doors from mcmaster.com for $9.72 each?
I checked the ones at Austin Hardware and they want $47.07 EACH for them. I know several here have used them but that is a bit pricey even for me.
ImageMark (& Cindi)
planovet
The Cat Man
Postby mikeschn » Wed Jul 02, 2008 6:33 pm
Austin has gone way up in price!
Postby Arne » Wed Jul 02, 2008 6:50 pm
I was thinking of a hinge like that, but went, once again, with piano hinge. I wasn't sure the 1.75" framing on door and frame would be enough to hold the weight of the door with just 4 screws...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Sparksalot » Wed Jul 02, 2008 7:45 pm
Nice find. I was having a tough time swallowing the Austin price.
I'm looking at doing a second door for one side to accommodate a window ac unit during hot months.
Sparksalot
Images: 687
Postby Jiminsav » Wed Jul 02, 2008 8:01 pm
go to a boat repair store..they sell stainless steel ones for around 15 bucks a pair.
Jim in Savannah
Jiminsav
Images: 40
Postby Sonetpro » Wed Jul 02, 2008 8:08 pm
$47.07 :shock:
I bought the same hinges from them 2 years ago for like 10 bucks.
I guess they found out how popular they are and are getting greedy.
Sonetpro
Images: 107
Re: Exterior Door Hinge
Postby tinksdad » Wed Jul 02, 2008 8:09 pm
planovet wrote:I checked the ones at Austin Hardware and they want $47.07 EACH for them. I know several here have used them but that is a bit pricey even for me.
I'm going to consider the McMasters hinge (and as someone in a later post suggested... a marine repair shop) for my hinges. I like the style; but when a pair of hinges costs more than the windows for the door.... even I draw the line somewhere!!!
tinksdad
Images: 155
Postby tinksdad » Wed Jul 02, 2008 8:15 pm
I know it's a stupid question.... but if you use that style hinge, which way do the pins go....up, down, one up one down????
tinksdad
Images: 155
Postby Sonetpro » Wed Jul 02, 2008 8:16 pm
I've found with Austin Hardware it is best to call them with your order. I have usually gotten better prices talking to them on the phone. Also when on the phone they can tell you what warehouse they are in so you can consolidate orders from one warehouse.
They have 4 warehouses around the country and if each one of the parts you order are in 4 different warehouse's you will get 4 shipping charges.
Sonetpro
Images: 107
Postby Steve F » Wed Jul 02, 2008 8:39 pm
tinksdad wrote:I know it's a stupid question.... but if you use that style hinge, which way do the pins go....up, down, one up one down????
The pins would have to face up when mounted to the wall of the TD or down when mounted to the door of the TD... Otherwise the door will fall off when you open it ;)
Cheers
Steve F
Images: 25
Postby tinksdad » Wed Jul 02, 2008 10:25 pm
DUH!!!!! After I hit the "submit" button, I realized I answered my own question. If I mount one pin up and one pin down.... without a screwdriver the door won't fall off and it can't be lifted off!! Mounted to the wall, bottom one up and the top one down.
tinksdad
Images: 155
Postby TPMcGinty » Wed Jul 02, 2008 10:30 pm
tinksdad wrote:DUH!!!!! After I hit the "submit" button, I realized I answered my own question. If I mount one pin up and one pin down.... without a screwdriver the door won't fall off and it can't be lifted off!! Mounted to the wall, bottom one up and the top one down.
Yea but maybe sometime you will WANT to lift it off. Mount them both up and you will have that option.
Tim
TPMcGinty
Images: 146
Postby starleen2 » Wed Jul 02, 2008 11:15 pm
Hey if jeeps can have removable doors , then why can't your TD have em :roll: :roll: ????
starleen2
5th Teardrop Club
Postby texasdog » Thu Jul 03, 2008 3:20 am
Why would you use a hinge that anyone with a screw driver can take off so they can steal your stuff? Am I missing something here?
THanks!
td
texasdog
Postby TPMcGinty » Thu Jul 03, 2008 3:54 am
texasdog wrote:Why would you use a hinge that anyone with a screw driver can take off so they can steal your stuff? Am I missing something here?
THanks!
td
If they want to get into it they will. I doubt if it matters what kind of hinge you have.
Tim
TPMcGinty
Images: 146
