Trackstriper wrote:Don't mean to hijack, but since we're sort of into this question, why is it recommended to keep the front of the trailer lower? I've heard this recommended before, and prefer it myself, but is there a solid reason to do so other than that some trailers just look goofy with the nose high? Is this to lower the trailer's aerodynamic drag and/or does it have to do with the dynamic stability of the trailer. Does this hold true for an open utility trailer without a body structure? Curious.
Trackstriper wrote:....why is it recommended to keep the front of the trailer lower?
G-force wrote:Under braking, especialy trailers with no brakes, all the trailers deacceleration is done by the tow vehicle. As you brake, the trailer is is being pushed into the tow vehicle. If its level, it will push in level. If the trailer is nose high, it will start taking weight off the rear wheels as it raises the coupler assembly. In a panic stop, you can get in the situation where enough weight is lifted off the rear wheels of the tow vehicle and the whole thing jackknifes. Having the trailer level, or slightly downward prevents this...
angib wrote:Trackstriper wrote:....why is it recommended to keep the front of the trailer lower?
I believe the reason is that most trailers have a fairly high centre of gravity and it lies fairly close to the axle.
So when you tip them nose-up, the centre of gravity moves backwards quite a bit, reducing the hitch weight and increasing the tendency to sway (actually what it does is reduce the speed at which swaying will start).
I think most of us have experienced with utility or box trailers that if you lift the nose high enough, the centre of gravity moves behind the axle and the trailer wants to tip over backwards. This shows just how sensitive trailers can be to their ride angle.
Andrew
brian_bp wrote:G-force wrote:Under braking, especialy trailers with no brakes, all the trailers deacceleration is done by the tow vehicle. As you brake, the trailer is is being pushed into the tow vehicle. If its level, it will push in level. If the trailer is nose high, it will start taking weight off the rear wheels as it raises the coupler assembly. In a panic stop, you can get in the situation where enough weight is lifted off the rear wheels of the tow vehicle and the whole thing jackknifes. Having the trailer level, or slightly downward prevents this...
This doesn't make any sense to me. The effect which is described here is real, but depends only on the ball height - whether the frame of the trailer is level or not is irrelevant.
By this standard, all towing balls should be as low as possible (and there's something to be said for that), regardless of trailer attitude.
