Singin the Gas Shocks Boogie - New Pics
Postby toypusher » Tue Jul 08, 2008 7:12 pm
Gee its 0308 and were struttin the gas
Can't put any time constraints on that!!! :shock: :shock: :lol:
toypusher
Images: 324
Postby Sonetpro » Tue Jul 08, 2008 7:13 pm
I think your problem might be the strength of the struts. I converted Newtons and 170N = 38.217520327 pound-force.
If those are 38 lb struts they won't be enough. Your hatch looks to be about the same size as mine and I have 2 90 lb struts on it.
Sonetpro
Images: 107
Postby Classic Finn » Tue Jul 08, 2008 7:14 pm
Tony also one thing notice that our bottom barcket is not flat? It has a built in gap ...would that cause a problem or should I go get a totally flat bracket?
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Sonetpro » Tue Jul 08, 2008 7:16 pm
Classic Finn wrote:Tony here is the top bracket we have and the way it was installed.
And Lower Bracket
I have mine installed the same way.
As Kerry said put the big end up. That way the oil stays on the seal and it won't dry up and crack.
Sonetpro
Images: 107
Postby Classic Finn » Tue Jul 08, 2008 7:18 pm
Sonetpro wrote:I think your problem might be the strength of the struts. I converted Newtons and 170N = 38.217520327 pound-force.
You know Steve the more Ive been staring at these the more I see that these are just not strong enough as well, now that you verified this also in Newtons.. Im willing to bet these are wrong..
So in your opinion should I go double or triple even on the shocks? Just so I dont go too heavy again.
Classic Finn
Classic Finn
Images: 146
Postby Classic Finn » Tue Jul 08, 2008 7:19 pm
And Lower Bracket
I,ll have them totally changed around.. thank you as well Steve.
Classic Finn
Images: 146
Postby Classic Finn » Tue Jul 08, 2008 7:33 pm
Well Im going to sleep for a few hours its getting sort of late.. also the sun is starting to shine quite bright at 03:29 hrs.
But anyways I want to say thank you for all the photos and information and help on this problem.. I,ll get back to you with this again with a cup of coffee.
Ohh thats in 4 hours. :lol:
So good night everyone. :thumbsup:
Classic Finn the Rookie Gas Shock installer. :lol: :lol: :?
Classic Finn
Images: 146
Postby QuietOutdoorsman » Tue Jul 08, 2008 9:02 pm
Finn,
You're going to want to pick up some struts in the 100-120 lb range (444 - 530 Newtons). The same 10/20 inch length of the strut will work and allow you to attach at about 6 inches from the hinge.
Disclaimer: Even the 120 lb strut might be a bit on the high side. 150 lb struts might prevent you from closing the hatch, and that's no way to be driving back from camp! :o
Dirk
QuietOutdoorsman
Postby Classic Finn » Wed Jul 09, 2008 1:53 am
Good Morning from Reindeerland.
I called the shock company and they said it was indeed too weak to carry the hatch on our voyager. they were very apologetic and said they will call me back shortly with an idea for new ones.
I,ll keep you posted as to how things go.
Ahh Id sure prefer to come back from camping with a closed hatch :lol: :lol:
Dirk thanks ;)
Classic Finn
Images: 146
Postby Classic Finn » Wed Jul 09, 2008 2:13 am
By the way
I have a question. Is it better to have the cabinets in place 1st before adding the shocks?
Classic Finn :thinking: :oops:
Classic Finn
Images: 146
Postby Classic Finn » Wed Jul 09, 2008 2:58 am
Ok the company called me back and they said that they have about the same length but 440 newtons = 98.915935 pounds force. In stock.
Close to what Sonetpro mentioned as far as weight .
or 98.915935 pounds = 44.8675134 kilograms. They said that this time it should be sufficient.
So Im going to go pick them up. Back Later but after install. ;)
Classic Finn
Images: 146
Postby Ivar the Red » Wed Jul 09, 2008 6:03 am
Classic Finn wrote:Ok the company called me back and they said that they have about the same length but 440 newtons = 98.915935 pounds force. In stock.
Good luck!!! :thumbsup:
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby Classic Finn » Wed Jul 09, 2008 6:57 am
Ok just got home.. New shocks on hand. 8) 8)
This time with 450 Newtons..or 450 newtons = 101.164024 pounds force.
Now to reread the info here from Tony so I dont make mistakes.
I just wish I would of known about this Newton equation thing or been familiar with it.. I am now... :lol: :lol:
Ohh well live n learn. Now to go install.. I,ll let you know how it went. ;)
Sonetpro what do you think about the size now?
Classic Finn ;)
Classic Finn
Images: 146
Postby Tripmaker » Wed Jul 09, 2008 7:34 am
Looks like you need to reverse your mounting points. Mount the lower end, attached to the galley walls closer to the hinge, and the mount attached to the hatch further from the hinge. I used starwheel supports so lifting it is by the armstrong method. But with gas struts this configuration requires less effort to lift the hatch.
When you close the hatch the support rotates downward. Mounted vertically like you have it you are limited to lowering the hatch to the closed length of the cylinder.
Jim
Tripmaker
Images: 59
Postby Sonetpro » Wed Jul 09, 2008 8:35 am
Classic Finn wrote:Ok just got home.. New shocks on hand. 8) 8)
Classic Finn ;)
The size sounds much more like it. Here is how mine are mounted. Almost the same as yours.
Sonetpro
Images: 107
